Karthik R
Administrator
Hello,nWhat initial values are you using in your simulation?nAre you running a transient model? What are your boundary conditions on the walls of the copper tube?nWhat is your time-step and is your simulation converging every time step?nWhat viscous model did you use to simulate this flow (and heat transfer)?nKarthikn
