Matt Madore
Array there should be a ProductConfig.exe. I recommend uninstalling and reinstalling. Make sure you are installing using Right-click -> Run as administrator. Another problem that may be happening is that you may not be able to edit the registry, that can cause the errors in the install. Can you share the C:\Program Files\ANSYS Inc\ANSYS Student\v211\CADConfigLogs\Latest\CADConfigurationMgr.log file? n
