DrAmine
You can enable solution animation to let the scene or contour plot be updated every N steps. Same can be done with Calculation ACtivities.nnLet's stick to the main issue here: Yes after one time step or even after one iteration in a time step: do you see a massive change in the pressure field after the initialization?n
