SIGSEV means there is data missing somewhere, ie you may be making a call in the UDF before the data exists. What surfaces are you linking? The initial post implied the domain inlet and outlet were linked. If it's a portion of the domain and there is bypass flow it's usually OK: we'd consider modelling jet fans in this way. n
