Erik Kostson
There should be an option to scope the displacements to a remote point, if not create a nodal name selection of the remote points (select the point on the tree , right mouse button click -> promote to named selection) and then use that (named selection) for scoping in the displacement results.nnThe easiest would be though in the scoping method of the results, to choose result files item, element name IDs and write below 21 (mass21 is the point mass element), just as shown below.nnnHope this helpsnErikn
