VivekKamble
,nIt seems you are able to plot the magnitude of the E filed. There is no direct method to see the phase of the E field, Calculation of the phase angle is possible using a fields calculator. nyou can find the field calculator here, nYou can calculate phase angle using the following expression,nnnPlease refer to the following online HFSS help, nhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/Electronics/v211/en/Subsystems/HFSS/HFSS.htm%23HFSS/SpecifyingthePhaseAngle.htm%3FTocPath%3DHFSS%2520Help%7CHFSS%2520Technical%2520Notes%7CThe%2520HFSS%2520Solution%2520Process%7CField%2520Solutions%7C_____3nThanks,nVivekn
