BenjaminStarling
Hi Array,nCreate a Named Selection of all vertices where end releases are to be applied. Name it release_nnCreate Worksheet based named selection that selects the elements attached to those nodes (or manually select them). Name it release_enYou can use a command snippet in the environment to apply the endreleases. n/PREP7ncmsel,s,release_n,nodencmsel,s,release_e,elemnendrelease,-1,,ROTX,ROTY,ROTZnallseln/SOLUnThe endrelease command can also do this automatically, without prior selection of elements, but selecting just the elements and nodes you would like to release is good practice, and ensures only those are the ones that are released. nhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/ans_cmd/Hlp_C_ENDRELEASE.htmln
