YasserSelima
nTav is the average temperature of the surface ... this IF statement means that if the value of Tav is larger than 150, the heat flux becomes X ... if not, the heat flux becomes 0 ... so, during the simulation, fluent will turn on and off the heat flux depending on TavnnTav will be another expression that uses area weighted average of the temperature on the surfacen
