BenjaminStarling
How are you applying the load to the structure? Is this using Mechanical or Mechanical APDL? If in Mechanical, the default application of loads uses surface elements, which can lead to some rounding errors. We would need more information about your project to assist further. Screenshots of your model and loads is a good place to start.n
