1shan
,nYes indeed. You could insert a contact tool to monitor the effect of increased tension, like the contact pressure/frictional force etc. You could also monitor the angular speed, moments at joints using joint probes. If you are a beginner I suggest you could take some of these free course(especially related to contact and rigid dynamics) which will give you a good idea about how to setup the analysis.nRegards,nIshan.n
