Keyur Kanade
You will have to use reverse engineering tools shared. nIn such complex geometry auto skin may not work. You may need to do it manually. nAlso please check if you can take only one repetitive portion of this geometry. Use reverse engineering tools to create solid. Then repeat that solid to get full geometry. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
