Karthik R
Administrator
Also, check what reference values you are using to calculate the drag coefficient. You should pay attention to density, velocity, and area. For every case, you should change these parameters.nA general comment - when comparing these values, you should always make sure that you have the same deep convergence for each solution/simulation you run.nKarthikn
