Karthik R
Administrator
What means is - how does your total input energy (in J) compare to the sensible and latent heat added to your fluid. This is a simple hypothetical energy balance.nm x Cp x del_T vs. Total input energynCompare these two quantities and see how much del_T you should expect if all the heat were added to increase the temperature. If this is small, then if you have phase change in your simulation, this temperature change would be further reduced.nKarthikn
