YasserSelima
So, you set the mass flow at inlet_1 as 6*0.504 = 3.024 kg/s and for inlet_2, you set the mass flow as 1.512 kg/s ??nif yes, are you calculating the velocity component normal to the boundary?nif yes, not sure what is wrong ... but you can use velocity inlet boundary instead of mass flown
