If you don't have the mass fraction of each size band how will you know if you're using the same distribution as the paper? The paper will have used 1008 parcels: the terms are (incorrectly) used interchangeably by everyone, including us. I set up the distribution using several injections of varying mass each with a fixed diameter. n
