FluentBatavia
If the value does not change from Mach 0 to 4, the direction of the force does not seem to be a problem.FluentBatavia, have you checked that you have selected the whole surface of your body?Another way to detect the error is to plot contours of pressure, velocity and density at different flow speeds. Mach 0.5, 0.8, 1.2 and 1.5, for example. With these simulations you will able to detect the shock waves, as well as the pressure distribution in the wake region. In the proposed cases, the variation in the drag force should be important.https://forum.ansys.com/discussion/comment/109075#Comment_109075
nWhy should I change anything but the velocity? The area definitely stays the same, should I change the density because of compressible flow?.Thank you both for your answers.n
