HDLI
For induction motor simulation, I suggest you to use AC Mains (voltage driven) and we will not see this error message any more. However, if you use Inverter Fed (current driven), we have to fully understand the theory relationship between slip, current, voltage and torque, and can decrease current and slip to match the DC bus voltage limit. In conclusion, the error message means we do not have the sufficient voltage to generate the power for any machines. Please check your input and decrease phase voltage.n
