YasserSelima
This is convergence. I understand that one value is relatively large ... but this doesn't mean the solution is not converged. All residuals are below 1e-03 and further iterations do not change the solution. To make sure it has converged, try monitoring the temperature at certain location or the velocity ... you should find it constant or having small oscillations around a valuenn
