1shan
,nSince the problem is pretty simple, you should be getting a close correlation between analytical and simulation. When you inset a point load there is a chance of singularity, so a convergence study is necessary. Please check this video
You may follow the same methodology and modify the supports according to your requirements.nRegards,nIshan.n n
