roshin
Hello,Yes, something seems off here. When you share Topology, the edge should be shared between the adjacent faces and Fluent should recognize it as the interior. Either way, if you are able to change from wall to interior, that would be the correct setting for what you are attempting to model.Karthikhttps://forum.ansys.com/discussion/comment/108595#Comment_108595
Oh okay Array Thank you so much sirs Arrayn
