YasserSelima
You must enable the energy equationnSo, the blue is defined as solid zone, and the brown is defined as fluid ... The outer wall of the blue has a constant temperature of 60 C. nWhat about the inner wall of the blue? The bottom surface? And the top? do you have convection heat transfer to the air? or this is an adiabatic surface?n
