nThis is a woven fabric, so there are different properties in the Warp and Fill directions.nWhat is the sheet thickness?nWhat is the fiber material?nWhat is the binder material?nDo you have the material properties of the fiber and binder?nANSYS has ACP/Pre that allows you to define a composite material and put fibers down in two directions and hold them together with a binder.n
