Evgenii_K
ACP / Pre, I have already checked it will not work. To solve the problem, I need to convert the units of measurement to MPa and assign the properties of the material in the third direction. But those properties of the material that I have, they are not required for Hill's fluidity, for this task the stresses radiated during stretching and sliding are needed, and this experiment must be done three times, but I only have this data with them and I need to work with them. The question is, how can the experimental data be reduced to MPa and is it possible to take voltages from the diagram ?! The diagrams that in the report I converted into an electronic version and tried to use them in the model of hyperelastic materials, but here too, failure.nMaterial thickness 1 mm, base material polymer reinforced with fiberglass meshn
