No, negative cell volume means the cell is flat, ie has no volume. That's very bad for the solver. No need to use the hex near the wheel, it was a suggestion to decrease the cell count out in the far field. If nothing is happening (ie flow isn't changing) you could also just use a coarser tet mesh. n
