YasserSelima
Numerically, there are many reasons that could cause this jump in the pressure. The most common one I know is not deeply converged solution. I would suggest repeating the same simulation, using tighter convergence criteria and increasing the maximum number of iterations per time step. Then you can see if the jump disappears or notn
