YasserSelima
Decrease the under relaxation factors. And check the box, use higher order relaxation. If you are doing unsteady simulation, decrease the time step and increase the number of iterations in every time step. If running steady, Pseudo transient is a good option.nDepending on the application. If you are using this to test theory or to make a draft design, yes ... but if you want to publish this data or to optimise a design, no. n
