jeny
Hi sir,nI am getting reasonable results now.. Although I din't change much! I have another question if I may, I want to do power cycling on the same module. I need to give internal heat generation to the silicon chip with time loading. But, I am not able to input time in analysis settings the same way as the screenshot I have attached. Could you please guide me on how to give time and heat generation properly so as to be similar with the plot attached. Supposing the internal heat generation rate is 3.5W/mm3 and the ramp time is 1 second with dwell time of 59 seconds. nThank you.nn
