YasserSelima
When you run First-order with a set material properties, you get a good preliminary solution. Then, when you use higher order terms, you are refining the solution.nWhen you change the properties after obtaining the preliminary solution, the problem becomes a different problem. And your preliminary solution might not be valid.nCan you show your mesh? and the residuals plotn
