Keyur Kanade
If you want to use 2D then make sure that you create geometry in XY plane. nIf you have created it and not able to select 2D in properties, then please check if this happens to all projects or only this one. nPlease try to uninstall and reinstall program. The installation may not be correct. If it is installation issue, please create a discussion under installation category. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
