1shan
,nCould you share some information about the geometry, mesh, loading and also the results? Have you referred any article who have compared strain values around the notch and received a good correlation. Maybe you could try replicating their results first? I am not an expert but I believe making sure the DIC algorithms are correct would also be a challenging task, especially because of the complex 3 dimensional strains around the notch. Have you used any other experimental procedure (like strain gauge) to validate the DIC results around the notch.nnRegards,nIshan.n
