Keyur Kanade
Few things to check - nPlease check mesh. Does it have sufficient refinement? What is quality? Min orthogonal quality should be above 0.1. nIs your case converged? Have you created any report definition? Can you upload residuals image? nPlease cross check extends of your domain in Fluent using Domain - Mesh - Scale. Make sure you have using correct scale. nPlease make sure you have sufficient small time step. It should converge in each time step. nPlease check if you can use PISO scheme. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
