ANSYS_MMadore
Array Could you please open a Windows command prompt and run the command set without quotes and send the full output? Could you refer to this post to see if it may apply in your case? https://forum.ansys.com/discussion/comment/92545#Comment_92545nPlease also try this, make sure all ANSYS applications are closed, then try registering the DLL's by starting a Command Prompt with run as administrator , and issuing the following commandsnregsvr32.exe ole32.dllnregsvr32.exe atl.dllnregsvr32.exe oleaut32.dllnregsvr32.exe scrrun.dllnregsvr32.exe jscript.dllnregsvr32.exe vbscript.dlln
