ayodele1
Dear ANSYS,nI wanted to know which of the parameters of this hot fluid flow (@ 190C) I should setup for surface monitor. There is no flow mixing, there is just one fluid flow through the pipe section. I do not think temperature will be appropriate, and considering flow rate instead. nPlease can you advise me on the parameter to use as surface monitor for the flow simulation.nThanks in anticipation.nAyodele1 n
