ayodele1
Dear ANSYS,nI wanted to know which of the parameters of this hot fluid flow (@ 190C) I should setup for surface monitor. There is no flow mixing, there is just one fluid flow through the pipe section. I do not think temperature will be appropriate, and considering flow rate instead. nPlease can you advise me on the parameter to use as for surface monitor for the flow simulation.nThanks in anticipation.nAyodele1 n
