YasserSelima
The first step in CFD is to have a geometry and mesh.nWhat you can do is to design a geometry close to what you expect, and start meshing. Put the pressure boundaries you have, and check the mass flow. Adjust the geometry until you reach mass flow close to your case.nHint. use workbench and parameter ... this will make the job easiern
