reebaln
Hi Navya,nThank you for your response. The objects in the model are not intersecting. How can I check if the temp folder can properly read and write?nSome parametric simulations run and some don't.nAlso, the temp folder location is set to default and there is enough space on the Hard drive to read/write files to the temp folder.n
