YasserSelima
Before using the Node-id , check that all nodes read the same id. I remember in earlier case, each computing node was reading different cell-idnnjust print a message inside the loopn#if RP_NODEnMessage(Node %d , node id %d, myid, NODE_ID(v));n#endifnnAnd check the id's .. do they make sense?n
