Surya Deb
Hi Jo, nDid you test in both Serial and Parallel runs? Can you check if the UDF works with a Serial run?nYou can also use a more generic reflect condition using the examples in the link below for DEFINE_DPM_BC. nYou need to be careful about the signs that are being used.nPlease check this link.nRegards,nSDn
