Karthik R
Administrator
H,nPlease verify that your mesh quality is good (min orthogonal quality should be greater than 0.1)nRegarding the frame motion axis and origin, can you share a screenshot of your geometry? Also, how are you checking if the shaft is rotating in the y-direction?nKarthikn
