Keyur Kanade
You can do internal plus external in one session. This would require you to include internal and external domain in single session. Mesh them in single session. Please note that this will increase the mesh count. If you want to use kw sst, please make sure that you have defined inflation correctly. Please use last ratio method and then use first height of 1/10th of surface mesh size. This will help you to get good y+ value. You can find similar many discussions on this forum. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
