1shan
,nThe stress in a dynamic condition is different from that of a static condition(usually twice or higher). If you want to find the equivalent stress which would replicate the dynamic scenario than you need to multiply it by an impact factor. Check this out https://www.clear.rice.edu/mech403/HelpFiles/ImpactLoadFactors.pdf. You could convert the strain into displacements and insert a displacement load. I doubt if this would work since the strain is accompanied by accelerations (you need both the data). You may try to increase the pressure until you get the required experimental strain and use that for the analysis.nRegards,nIshan.n
