March 9, 2021 at 10:29 am
Thank you, for quick reply. Because there are many outlets, so the differences depend on the location of each outlet, but for the minimum difference is 57% and the maximum difference is 92%. The results of mass flow outlet after running calculation is smaller than the amount of mass flow outlet which I applied before running calculation from 57% to 92% according to the location of each outlet. Thank you! I will appreciate for all your advices!n
