March 10, 2021 at 3:46 am
Are you using student license?nWhich version you are using?nIs this error consistent if you import mesh from Ansys Meshing? Can you open stand alone Fluent instead of using workbench? Can you read any .cas file in Fluent?nHave you checked quality in ICEM? Please check if there are any negative elements. Please check orthogonal quality. nIf you are using any older version, recommend to use latest version.Regards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
