Govindan Nagappan
@prakhars962 nnTry changing the scale for result display and unit system to see if it makes a differencenAlso see if you can use the default legend. If it still doesnt work, consider using the APDL commands or APDL application for post processingnYou can use /expand command nSee example usage at 27.7. Results and Discussion (ansys.com)nn
