Deyu Li
Plot H field on select face is: n1 change select mode to facen2 select the face you would like to plot field onn3 right mouse click->Fields->H->Mag_HnnField calculator can create Hx, Hy, Hz name expressions, here is an example of doing Hx:n1 launch field calculatorn2 Input Quantity->Hn Scal?->ScalXn Vec?->VecX n Add... ->Hxn3 Select the face in the modeler window->right mouse click->Fields-> Named Expression->Hnn
