March 23, 2021 at 3:52 pm
How far along does your interference fit solve to? Please make sure that you have the following settings defined correctly:nPinball radius is more than the amount of interferencenInterface Treatment is set to Add offset, ramped effectsnHyperelastic part is chosen as Contact side nIn addition to that, it may help tonSet contact stiffness factor to 0.1nUse first-order elements for hyperelastic part if incompressibility parameter is zeronIf you haven't watched it already, then check out this video for a few more pointers.n
target=blank>n
