Guilin Sun
you can use set(set time domain,1); to enable a tab property. One this is enabled, you can set other properties, as you did in the script, such asnset(offset,3e-12);nplease note that the units in scripting are international standard, meter, second, kg etc.nnyou can usen?set; when an object is selected to know all its parametersnorn?setnamed(object_name) to know the parameters for a specific object.nnPlease try and check if all the set results are what you expect.n
