Your problem may well be that you're changing the density of the water in a sealed volume. The extra volume has to come from, or go to somewhere. Bousinesq approximation fudges the body force to mimic the temperature effect on density without changing the material density. nI knew about the water density peaking at 4C, didn't know it had a term. n
