ANSYS_MMadore
Array Your file indicates nInitial mount directory:n  C:\Users\Apple\AppData\Local\Temp\Rar$EXa5360.29510nnThis would indicate that you are not installing from the extracted files, but instead directly from the zip or temp files. You must extract the zip and run the setup from the extracted files. The install.log and install.err should be in C:\Program Files\Ansys Inc\Ansys Student
