Rashi
Quick check - Open Fluent and try to run each command one by one. You can copy paste the command in Fluent TUI. This will make sure that journal file commands are correct.https://forum.ansys.com/discussion/comment/112095#Comment_112095
Thank you for your suggestion. I tried it but the TUI works in GUI mode but does not work in batch mode.n
